3DS Max 2014 x64 için VRay 2.40 (cracked dll) Update !
unknown · 6300
Çevrimdışı unknown
    • İleti: 14
Not : Torrent Kullanmayı Bilmeyenler Öncelikle Bilgisayarına Torrent Kurulumunu ve Torrent Kullanımını Öğrenmelidir.
Bunun için buraya tıklayarak kurulumu ve kullanımı ayrıntılı olarak öğrenebilirsiniz.
İndirme Linki Konu Altındadır.
Description
Hi
Today with us amazing program for rendering I think everyone knows it
is VRay 2.40 for 3DS Max 2014 .
Now I leave you with the details :
New features:
(*) Support for 3ds Max 2014;
(*) V-Ray RT: Support for MultiScatter instancing;
(*) V-Ray RT: Support for Phoenix FD 2.1;
Modified features:
(*) V-Ray: Changed default settings of VFB’s sRGB button, “Don’t affect colors” option and “Gamma” value to suit Linear Workflow from the start;
(*) VRayCarPaint: Added support for displacement texture channel;
(*) VRayHDRI: Made file open dialog to remember the last used file type filter;
(*) VRayHDRI: The image file is now reloaded if it had been changed outside 3ds Max;
(*) VRayMtl: Added Self-illumination slot;
(*) Raw OpenEXR files now have ZIPS compression by default;
Bug fixes:
(*) VRayProxy: Objects pointing to vrmesh files without extension did not render;
(*) V-Ray RT: Fixed crash when a texmap is attached to an disabled environment override slot;
(*) V-Ray RT: Fixed error during initialization when Auto update bitmaps is enabled;
(*) V-Ray RT: Fixed wrong DOF with physical camera;
(*) V-Ray RT GPU: Fixed crash with materials with mapped IOR;
(*) VRayIESLight: Fixed issue causing wrong override shape dimensions when loading, if the previous scene had different units setup;
(*) VRayMultiSubTex: Fixed issue preventing drag and drop operations for subtex with index greater than 20;
(*) VRayPTex: Fixed a crash at the end of a rendering;
(*) V-Ray Light Lister: Fixed error in 3ds Max 2014;
Enjoy ;)
[This is the test from my PC ] :
İndirme Linki :
https://drive.google.com/file/d/0B3sQkri7ivlhTjFlczZUZS1PZEk/edit?usp=sharing
« Son Düzenleme: 05 Eylül 2014, 09:31:10 Gönderen: unknown »
Çevrimdışı byscary
    • İleti: 1
Yanıtla #1 : 05 Eylül 2014, 13:56:51
Dosyada virüs var yüklenmiyor..
    • İleti: 1990
Yanıtla #2 : 05 Eylül 2014, 15:51:24
crack dosyasını tüm antivirüsler  virüs olarak görür. bu yüzden antivirüsü kurulum sırasında kapalı duruma getiriniz.
Çevrimdışı cm
    • İleti: 2
Yanıtla #3 : 16 Eylül 2014, 19:28:35
hocam yukenme seklı ve cracleme nası
    • İleti: 1990
Yanıtla #4 : 16 Eylül 2014, 19:34:46
yukarıda ki gif resimde anlatıyor :)
Çevrimdışı cm
    • İleti: 2
Yanıtla #5 : 17 Eylül 2014, 19:05:22
ewet anlatıyor fakat ıkı kere ındırdımyukleme dosyası calısmıor
