Giriş Yap
Kayıt Ol
Ara
Ana Sayfa
Yardım
Giriş Yap
Kayıt Ol
Medeniyet Mühendisleri
Proje, Çizim ve Planlama Programları
Tekla/Xsteel
Tekla Structures v20.0 SR1 (x86/x64) Multilingual
« önceki
sonraki »
Yazdır
Sayfa: [
1
Aşağı git
6 Yanıt
11573 Gösterim
unknown
Çaylak
14
+0/-0
27 Ağustos 2014, 10:00:15 »
Tekla Structures software is a building information modeling (BIM), which allows you to create accurate, detailed, easy to construct 3D models from any material and any complexity and manage them . Models Tekla Structures can be used throughout the construction process from design to fabrication, erection and construction management .
Tekla Structures - is a single product that is available in several configurations that provide specialized functionality to meet the needs of certain segments of the construction industry.
Tekla Structures can be used with other existing applications, or solely as a platform to develop their own workflows . Its open platform supports interoperability and standardization. Tekla Structures links with various systems through Tekla Open API ™ application programming interface that is implemented using Microsoft ®. NET. For example , Tekla Structures supports the following standard formats : IFC, CIS / 2 , SDNF and DSTV. Tekla Structures supports proprietary formats such as DWG, DXF and DGN.
Download From Rapidgator
http://rapidgator.net/file/25cfb02cb5c82f95d0bbcf840f8a1e8f/xidau123_Tekla.Structures.v20SR1.part1.rar.html
http://rapidgator.net/file/1de48f52c972245c85e36da5a575f699/xidau123_Tekla.Structures.v20SR1.part2.rar.html
Download From Uploaded
http://uploaded.net/file/m0ovsl5v/xidau123_Tekla.Structures.v20SR1.part1.rar
http://uploaded.net/file/50ztyw0q/xidau123_Tekla.Structures.v20SR1.part2.rar
Kayıtlı
şahnaz
Çaylak
9
+0/-0
Ynt: Tekla Structures v20.0 SR1 (x86/x64) Multilingual
Yanıtla #1 :
01 Eylül 2014, 23:38:50 »
Sayfa bulunamıyor. Başka bir link var mıdır acaba?
Kayıtlı
Medeniyet Mühendisi
Admin
Yazar
1991
+43/-2
Yanıtla #2 :
02 Eylül 2014, 12:25:39 »
http://www.medeniyetmuhendisleri.com/forum/xsteel/xsteel-v20-full-indir-torrent-t536.0.html
bu konuyu inceler misiniz?
Kayıtlı
şahnaz
Çaylak
9
+0/-0
Yanıtla #3 :
30 Kasım 2015, 10:47:48 »
İyi günler
.dll uzantılı dosyaları nereye eklemem gerekiyor?
Kayıtlı
Medeniyet Mühendisi
Admin
Yazar
1991
+43/-2
Yanıtla #4 :
30 Kasım 2015, 11:04:53 »
crackleme yapmak için program files içinde bulunan teklanın kurulum dosyasına atmanız lazım diye biliyorum
Kayıtlı
şahnaz
Çaylak
9
+0/-0
Yanıtla #5 :
30 Kasım 2015, 11:38:50 »
Daha önce versiyon 20 yi kurmuştum ve hiç bir problemle karşılaşmamıştım. bu sefer sıkıntılı oldu. Eğer mümkünse bir anlatım yapılabilinir mi? Şimdiden sağ olun.
Kayıtlı
tugrul3019
Yeni Üye
1
+0/-0
Yanıtla #6 :
17 Aralık 2015, 00:34:16 »
32 bit için başka indirme linki mevcut mudur acaba? Yukarıdaki linklerde dosya bulunamıyor.
Kayıtlı
Yazdır
Sayfa: [
1
Yukarı git
« önceki
sonraki »
