SAP2000 YÜK KOMBİNASYONLARI HAKKINDA
Ahmet Hocam merhaba
sap2000 yük kombinasyonlarımı girdikten sonra “no cases set to run” hatası alıyorum. artık çalışmam kombinasyonları silsem dahil analiz yapmıyor. kombinasyonları export edip farklı bir dosya adı ile tekrar import ettikten sonrada şöyle bir rapor veriyor ;********** DATABASE IMPORT DEFINITION DATA **********
SAP2000 Version 15.1.0 Text File/Access Database Import
Imported C:UsersPcDesktopÖRNEK 11.s2k
Import Type and Options: Add to Existing Model
Elements with Same Name in Model and DB:
Other Items with Same Name in Model and DB:
Elements (Except Links) in the Same Location: Allow duplicates in the same location
Link Elements in the Same Location: Allow duplicates in the same location
Items With Same Name in a DB Table: Overwrite previous item
Import Control for Errors: Abort import after 20 errors
Import Control for Warnings: Abort import after 200 warningsImport started at 15:35:45
Import completed at 15:35:49
Number of errors: 0
Number of warnings: 9
Number of informational messages: 7********** DATABASE IMPORT SUMMARY LOG **********
PROGRAM CONTROL Table: 1 of 1 records successfully read
LOAD CASE DEFINITIONS Table: 0 of 8 records successfully read
CASE – STATIC 1 – LOAD ASSIGNMENTS Table: 0 of 7 records successfully read
CASE – MODAL 1 – GENERAL Table: 0 of 1 records successfully read********** DATABASE IMPORT DETAILED LOG **********
*** Warning Message 1 ***
Table name: LOAD CASE DEFINITIONS
Field name: CASE
Record: 1
Load case MODAL already exists; record skipped*** Warning Message 2 ***
Field name: CASE
Record: 2
Load case G already exists; record skipped*** Warning Message 3 ***
Field name: CASE
Record: 3
Load case Q already exists; record skipped*** Warning Message 4 ***
Field name: CASE
Record: 4
Load case EXP already exists; record skipped*** Warning Message 5 ***
Field name: CASE
Record: 5
Load case EXN already exists; record skipped*** Warning Message 6 ***
Field name: CASE
Record: 6
Load case EYP already exists; record skipped*** Warning Message 7 ***
Field name: CASE
Record: 7
Load case EYN already exists; record skipped*** Warning Message 8 ***
Field name: CASE
Record: 8
Load case EZ already exists; record skippedLOAD CASE DEFINITIONS Table: 0 of 8 records successfully read
*** Informational Message 1 ***
Table name: CASE – STATIC 1 – LOAD ASSIGNMENTS
Field name: CASE
Record: 1
A static load case G previously existed in model; record skipped*** Informational Message 2 ***
Field name: CASE
Record: 2
A static load case Q previously existed in model; record skipped*** Informational Message 3 ***
Field name: CASE
Record: 3
A static load case EXP previously existed in model; record skipped*** Informational Message 4 ***
Field name: CASE
Record: 4
A static load case EXN previously existed in model; record skipped*** Informational Message 5 ***
Field name: CASE
Record: 5
A static load case EYP previously existed in model; record skipped*** Informational Message 6 ***
Field name: CASE
Record: 6
A static load case EYN previously existed in model; record skipped*** Informational Message 7 ***
Field name: CASE
Record: 7
A static load case EZ previously existed in model; record skippedCASE – STATIC 1 – LOAD ASSIGNMENTS Table: 0 of 7 records successfully read
*** Warning Message 9 ***
Table name: CASE – MODAL 1 – GENERAL
Field name: CASE
Record: 1
A modal load case MODAL already exists; record skippedCASE – MODAL 1 – GENERAL Table: 0 of 1 records successfully read
